Crystal Mechanics
How would I model the shear stress slip and direction in a crystal? In other words, if I have all the necessary material information how can I use the 3D structural mechanics module in Comsol to figure that out.
Thank you
1 Reply Last Post 2010年3月13日 GMT+8 15:18
Posted: 2 decades ago 2010年3月13日 GMT+8 15:18
well for me that means selecting "anisotropic material properties" and play with the full tensors, and extensively with the coordinate systems.
I beleive you need the structural or the mems module to take full benefit of this
One thing, check carefully the numbering of the indexes, as there are many norms, and COMSOL uses different coordinates for standard material and for PZT material, following the main definition commonly used. This is well described in the doc, but very easy to forget while programming
Hi well for me that means selecting "anisotropic material properties" and play with the full tensors, and extensively with the coordinate systems. I beleive you need the structural or the mems module to take full benefit of this One thing, check carefully the numbering of the indexes, as there are many norms, and COMSOL uses different coordinates for standard material and for PZT material, following the main definition commonly used. This is well described in the doc, but very easy to forget while programming Good luck Ivar
