Line Graph using expression for x-axis
I am doing magnetic field simulations to validate analytical models. For this I need to have the line graph of the radial field in the airgap for example. This works fine, as long as I plot it over the arc length. However I would like to plot it over the angle. I defined an angle (sys2.phi) and the plot works fine, except that Comsol connects the end with the start with a straight line, which messes up my plot.
Does anybody know how to get rid of this connection?
Is there a way to plot over [0, 2Pi), which would solve the problem?
Regards
Yannick
3 Replies Last Post 2013年12月3日 GMT-5 06:22
Sven Friedel COMSOL Employee
Posted: 1 decade ago 2013年9月23日 GMT-4 05:29
Hi Yannick,
Can you send a sample model to illustrate what you mean?
Sven
Hi Yannick, Can you send a sample model to illustrate what you mean? Sven
Posted: 1 decade ago 2013年9月23日 GMT-4 07:16
Thanks for the quick reply
The screenshots illustrate the behaviour.
The x-Axis-Data uses the Parameter: Arc Length or Expression.
With expression I use sys2.phi as the parameter.
Hope this is what is needed,
Yannick
Thanks for the quick reply The screenshots illustrate the behaviour. The x-Axis-Data uses the Parameter: Arc Length or Expression. With expression I use sys2.phi as the parameter. Hope this is what is needed, Yannick
Jes Bøgeskov Thomsen
Posted: 1 decade ago 2013年12月3日 GMT-5 06:22
Hey all,
I do I have the same problem and it will be great if anyone can answer how for deleting the straight line
regard Jes
Hey all, I do I have the same problem and it will be great if anyone can answer how for deleting the straight line regard Jes
