Hello Denis Maus
2014年3月31日 GMT+8 21:52
did you find an answer for your question? I also working on Mac OS and would very much like to be able to open multiple comsol models at the same time.
//Ellen
//Ellen
2014年4月9日 GMT+8 15:18
no, unfortunately i did not found a solution.
2014年6月26日 GMT+8 21:58
You can run a new instance by using the following command in the Terminal.
open -na "COMSOL Multiphysics.app"
Procedure to open from COMSOL installation directory:
1.- Open Terminal
2.- Go to your COMSOL Directory example: "cd /Applications/COMSOL44"
3.- Use the command : "open -n "COMSOL Multiphysics.app"
Done a new instance should be running. You can do the same for other versions of COMSOL.
Kind Regards,
Arpys
1.- Open Terminal
Kind Regards,
Arpys
2014年6月27日 GMT+8 04:57
Thanks for the solution, Arpys.
also worked well with Comsol 4.3b.
[QUOTE]
[/QUOTE]
