matlab coder C++ executable
Is there any work around for using the "import" function when coverting a matlab *.m file to a C++ executable? I'm trying to convert a COMSOL *.m file to an exe file and I have to use import com.comsol.model.* and import com.comsol.model.util.*
Matlab gives me this response: "Import statements are currently unsupported." and I just wanted to know if COMSOL had a work around for this.
2 Replies Last Post 2013年10月17日 GMT-4 06:50
Posted: 1 decade ago 2013年10月15日 GMT-4 16:22
If anyone is curious, it appears that the answer is 'no' based on this thread from stackoverflow unless COMSOL people have an idea.
stackoverflow.com/questions/19386690/import-function-matlab-coder-and-c-executable
If anyone is curious, it appears that the answer is 'no' based on this thread from stackoverflow unless COMSOL people have an idea. http://stackoverflow.com/questions/19386690/import-function-matlab-coder-and-c-executable
Posted: 1 decade ago 2013年10月17日 GMT-4 06:50
The COMSOL API is based on a connection from your application to COMSOL that uses Java. There is no way to avoid this.
You should be able to use Matlab Compiler to compile your Matlab scripts, but you'll still need a working Comsol installation in order to make everything work.
Lars Gregersen
Comsol Denmark
Hi The COMSOL API is based on a connection from your application to COMSOL that uses Java. There is no way to avoid this. You should be able to use Matlab Compiler to compile your Matlab scripts, but you'll still need a working Comsol installation in order to make everything work. Lars Gregersen Comsol Denmark
