How export data using MATLAB Link?
Hi All
I need information, how I can export data by vertex using MATLAB?
Before solve my problem, first I obtain information about mesh:
nElem = model.mesh('mesh1').getNumElem;
nVertex = model.mesh('mesh1').getNumVertex;
Vertex = model.mesh('mesh1').getVertex();
Elem = model.mesh( 'mesh1').getElem('tri');
After solve problem:
model.study('std1').run;
I would like to want obtain set of data (some expression) in each of these vertex.
I dont want to use the export function
model.result.export('data1').set('filename', {NameFile});
model.result.export('data1').run;
because it generates its own mesh.
Regards
1 Reply Last Post 2014年9月27日 GMT+8 05:55
Hello Antoni Adapter
Posted: 1 decade ago 2014年9月27日 GMT+8 05:55
Antoni,
Unfortunately I dont know the answer of your question. But could you help me out to export the data that you mentioned here?
I mean, how can I export "data1" to a csv file (or any other text formats) ?
Thanks a lot
my code:
model.result.export.create('data1', 'Data');
model.result.export('data1').setIndex('expr', 'u4', 0);
model.result.export('data1').set('filename', 'C:\Program Files\COMSOL\COMSOL44\u4.csv');
model.result.export('data1').name('u4');
Antoni, Unfortunately I dont know the answer of your question. But could you help me out to export the data that you mentioned here? % model.result.export('data1').set('filename', {NameFile}); model.result.export('data1').run; % I mean, how can I export "data1" to a csv file (or any other text formats) ? Thanks a lot my code: model.result.export.create('data1', 'Data'); model.result.export('data1').setIndex('expr', 'u4', 0); model.result.export('data1').set('filename', 'C:\Program Files\COMSOL\COMSOL44\u4.csv'); model.result.export('data1').run; model.result.export('data1').name('u4');
