2D, Magnetic and electric field module
Posted 2013年12月9日 GMT+8 01:17 Version 4.3 3 Replies
Hi everyone,
I'm trying to model a very basic problem.
I have a conductive current carrying wire (an extremely thin wire actually) and I would like to obtain the spatial distribution of the magnetic field created by the current flow.
I'm using the "magnetic and electric fields module".
The first question is,:
Is there an easy way to define a thin wire in order to eliminate all the meshing/memory issues?
The second problem is that, in addition to the difficulties in meshing a thin geometry (I kinda solved it by using a "swept" mesh) , in 3D everything works fine: I set an electric potential across the wire and, and I get a current and magnetic field as a result. On the other hand, in 2D if I set the the electric potential on the bounds of the wire, I ONLY get the current as a result (the magnetic field is '0' everywhere, and so is the magnetic energy).
Any ideas on how to solve these two problems?
Thank you in advance!
3 Replies Last Post 2015年3月2日 GMT+8 23:50
