Hello kishore naik
9 years ago
2015年12月4日 GMT+8 00:42
Hello Kishore,
Have you find a solution to your problem? I'm trying to get similar results in COMSOL 4.4.
I want to compute the coupling coefficient between a single turn coil with a round cross section and a flat plate at frequencies between 50 kHz and 150 kHz. The plate and the coil have linear permeability. I built a 2D axisymmetric mf model where I used single turn coil domains for the coil and the plate. I imposed a 1A current in the coil and 0V in the plate.
I computed the mutual inducance using M = Vplate/(Icoil*omega*j) and the self inductances using the magnetic energy in the coil domain (L1) and in the plate domain (L2). I computed the induced voltage (Vplate) doing the volume integral of the vector potential (j*omega*int(mf.Aphi)/Area). I must do something wrong because the coupling coefficient I get is too small (k = 0.0001).
Any hints would be appreciate.
Mathieu Gendron
Hello Kishore,
Mathieu Gendron
9 years ago
2015年12月4日 GMT+8 00:50
HI Mathieu,
I found this, by just diving K= M/L (In My case LT and LR is same). What is distance between your coils. Just check current density, coil parameters you applied is correct or not.
kishore Naik Mude
HI Mathieu,
kishore Naik Mude
9 years ago
2015年12月4日 GMT+8 01:17
Hi Kishore,
Thank you for your quick answer. The distance between the coil and the plate vary between 1 and 10 mm, I expect k to be between 0.7 and 0.2. In my case, I don't think I can use k=M/L because the plate and the coil don't have the same self inductance.
Best regard,
Mathieu
Hi Kishore,
Best regard,
Mathieu
9 years ago
2015年12月4日 GMT+8 07:44
Hi Mathieu,
Perhaps the reason for the low inductance value is because the plate is in short circuit mode due to the application of V = 0V across it. The inductance value would then be the short circuit inductance as seen from the coil side. You can also cross check the value obtained with the energy method. Here,
0.5*L*I^2 = W (energy calculated over the entire volume)
Girish
Hello Kishore,
Mathieu Gendron
Hi Mathieu,
Girish
[QUOTE]
Hello Kishore,
Mathieu Gendron
[/QUOTE]
