Filtration of nanoparticles in porous membrane
Posted 2014年2月18日 GMT+8 04:36 Charged Particle Tracing, Fluid & Heat, Particle Tracing for Fluid Flow, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.4 4 Replies
Hi all, I'm simulating the rejection of nanoparticles that pass through a porous membrane.
I am using the physics of "Particle tracing for fluid flow" and "Laminar flow" and set up some particles bigger than the pore size so that those particles are supposed to be rejected (not pass through the membrane).
I expected those big particles would remain on the membrane surface, not passing though membrane.
But I found that all of them pass through the membrane when I check the statuses of their final deposition.
Do I have to use another module to simulate the particle filtration though a porous membrane or is there some thing that I may miss?
Thank you for your reply!
Dukwoo
Dukwoo
4 Replies Last Post 2014年10月1日 GMT+8 07:42
