Problem when trying to simulate solar cell
Posted 2014年2月22日 GMT+8 02:57 Semiconductor Devices Version 5.0 4 Replies
Hello everyone, I am new to Comsol and am trying to simulate a simple silicon solar cell using the semiconductor module. I can setup the PN junction and find IV curves with no problem. However, when I try to enter an electron and hole generation rate using the "User Defined Recombination" the solution won't converge. I get the following error message:
Failed to find a solution for the initial parameter.
Maximum number of Newton iterations reached.
Returned solution is not converged.
- Feature: Stationary Solver 1 (sol1/s1)
I am using a generation rate of 10^32 [1/(m^3*s)] and the volume of my cell is 10^-17 [m^3], corresponding to the generation of 10^15 carriers per second. Assuming no recombination, this will lead to a current of approximately 1 mA. If I use a lower generation rate (10^25 [1/(m^3*s)] ) the solution will converge, but I get negligible photocurrent. I have attached my simulation. Any help, or tips would be much appreciated!
-Kevin
-Kevin
4 Replies Last Post 2016年6月6日 GMT+8 22:25
