twice the true magnitude of the volume calculated in this axissymmetric 2D" approach with the Gauss formula
If I calculate a volume with COMSOL in an "axissymmetric 2D" approach I can use two different ways:
Both utilize the way:
Definitions/Component Couplings/intgegration
1) I can directly choose a "domain" - carefully observing the need to check the checkbox "Compute integral in revolved geometry"
2) I can choose all boundaries and use the Gauss formula "SurfaceIntegral(r*solid.nr)" as the target.
The surprising fact is, that way #2 with the Gauss formula computes twice the true volume in this axissymmetric 2D" approach while it calculates correctly in the same way in the 3D approach.
I attach a mph file showing this behaviour.
Why is a result calculated which amounts the double magnitude of the correct result?
0 Replies Last Post 2014年3月5日 GMT-5 11:14
Hello Hans Gennerich
