stratification
Hi everyone!
Let's picture three objects densely pressed to each other. First object is heated, the other one is cooled, and the third is in between. Certain temperatures cause a gap between objects because of thermomechanical expansion and different properties of materials. How to make the progam see that three objects pressed to each other are not a single object? How to make in the program a microscopic gap between objects without geometrical modeling?
3 Replies Last Post 2014年3月13日 GMT+8 22:04
Niklas Rom COMSOL Employee
Posted: 1 decade ago 2014年3月12日 GMT+8 20:22
Hi Mikhail,
this is called thermal contact. See the two downloadable examples:
www.comsol.com/model/simulation-of-multiphysics-contact-in-a-power-conductor-4119
www.comsol.com/model/thermal-contact-resistance-between-an-electronic-package-and-a-heat-sink-14659
kind regards,
Niklas
Hi everyone!
Hi Mikhail, this is called thermal contact. See the two downloadable examples: http://www.comsol.com/model/simulation-of-multiphysics-contact-in-a-power-conductor-4119 http://www.comsol.com/model/thermal-contact-resistance-between-an-electronic-package-and-a-heat-sink-14659 kind regards, Niklas [QUOTE] Hi everyone! Let's picture three objects densely pressed to each other. First object is heated, the other one is cooled, and the third is in between. Certain temperatures cause a gap between objects because of thermomechanical expansion and different properties of materials. How to make the progam see that three objects pressed to each other are not a single object? How to make in the program a microscopic gap between objects without geometrical modeling? [/QUOTE]
Posted: 1 decade ago 2014年3月12日 GMT+8 21:00
Niklas Rom, thanks a lot!
Posted: 1 decade ago 2014年3月13日 GMT+8 22:04
Hi Mikhail,
kind regards,
Niklas
In the example (www.comsol.com/model/simulation-of-multiphysics-contact-in-a-power-conductor-4119), it is written that:
HEAT TRANSFER IN SOLIDS
Pair Thermal Contact 1
1 On the Physics toolbar, click Pairs and choose Pair Thermal Contact.
2 In the Pair Thermal Contact settings window, locate the Pair Selection section.
3 In the Pairs list, select Contact Pair 1.
4 Locate the Contact Surface Properties section. From the p list, choose Contact
pressure (solid/cnt1)...
but section Pairs does not contain Pair Thermal Contact ... I have 4.3a version... Where can I find Pair Thermal Contact?
[QUOTE] Hi Mikhail, this is called thermal contact. See the two downloadable examples: http://www.comsol.com/model/simulation-of-multiphysics-contact-in-a-power-conductor-4119 http://www.comsol.com/model/thermal-contact-resistance-between-an-electronic-package-and-a-heat-sink-14659 kind regards, Niklas [/QUOTE] In the example (http://www.comsol.com/model/simulation-of-multiphysics-contact-in-a-power-conductor-4119), it is written that: HEAT TRANSFER IN SOLIDS Pair Thermal Contact 1 1 On the Physics toolbar, click Pairs and choose Pair Thermal Contact. 2 In the Pair Thermal Contact settings window, locate the Pair Selection section. 3 In the Pairs list, select Contact Pair 1. 4 Locate the Contact Surface Properties section. From the p list, choose Contact pressure (solid/cnt1)... but section Pairs does not contain Pair Thermal Contact ... I have 4.3a version... Where can I find Pair Thermal Contact?
