beam buckling analysis
I am trying to analysis a beam buckling under gravity with different boundary conditions.
It can be fixed-free or fixed-fixed but slided in one direction.
Can anyone give some suggestions about buckling?
I studied the truss tower example and it seems that the beam has to been under unit load for buckling analysis.
Is this right?
thanks for anything.
3 Replies Last Post 2014年3月18日 GMT-4 09:53
Posted: 1 decade ago 2014年3月18日 GMT-4 02:39
If you use the "linear buckling analysis" study, it is based on a prestressed eigenfrequency analysis, so the output is a "security factor" with respect to the initial stress from the given load.
So if you give a "unit" load you have a security factor w.r.t. this unit load,
if you however define a nominal load, then your security factor is w.r.t. the nominal load value
For more, see Henrik's intersting blog on buckling :
www.comsol.eu/blogs/buckling-structures-suddenly-collapse/
Have fun COMSOLing
Hi If you use the "linear buckling analysis" study, it is based on a prestressed eigenfrequency analysis, so the output is a "security factor" with respect to the initial stress from the given load. So if you give a "unit" load you have a security factor w.r.t. this unit load, if you however define a nominal load, then your security factor is w.r.t. the nominal load value For more, see Henrik's intersting blog on buckling : http://www.comsol.eu/blogs/buckling-structures-suddenly-collapse/ -- Have fun COMSOLing Ivar
Posted: 1 decade ago 2014年3月18日 GMT-4 03:03
Please note that the Linear Buckling study type is not available for the Beam interface. It can currently only be used with the Solid Mechanics, Shell and Truss interfaces.
Henrik
Hi, Please note that the Linear Buckling study type is not available for the Beam interface. It can currently only be used with the Solid Mechanics, Shell and Truss interfaces. Regards, Henrik
Posted: 1 decade ago 2014年3月18日 GMT-4 09:53
Thank you very much for all help.
Yes I did use the solid mechanics model to do my study. I want to analysis the buckling of a drill string which should look like a hollow tube (or shell?). But I start with solid mechanics because it is easier. I have many difficulties with it. First one: can you tell me how to set up two boundary conditions? One end is fixed at the bottom and I used fixed contraint. I think this one is ok. Another end should be fixed at x and y direction and the top face of the beam could not rotate. But in z-axis, it is free to slide. I am not sure if I explain it clearly. I tried to use prescribed displacement but the top face is rotated.
Thanks again.
Thank you very much for all help. Yes I did use the solid mechanics model to do my study. I want to analysis the buckling of a drill string which should look like a hollow tube (or shell?). But I start with solid mechanics because it is easier. I have many difficulties with it. First one: can you tell me how to set up two boundary conditions? One end is fixed at the bottom and I used fixed contraint. I think this one is ok. Another end should be fixed at x and y direction and the top face of the beam could not rotate. But in z-axis, it is free to slide. I am not sure if I explain it clearly. I tried to use prescribed displacement but the top face is rotated. Thanks again.
