2009年8月12日 GMT-4 15:02
Hi, why don't you introduce a new general form PDE, call the dependent variable u with the following settings:
Gamma = 0 0
F = uy-f(x,y)
The solution to the PDE, u(x,y) is then the integral that you desire, i.e. u(x,y)=I2(x,y)=int_0^y f(x,y') dy'
To do this with coupling variables you would have to extrude the solution to a 3D prism and then project back to the 2D domain which is tricky and computationally more expensive.
/ Dan
COMSOL Development
Gamma = 0 0
F = uy-f(x,y)
/ Dan
COMSOL Development
2009年8月13日 GMT-4 04:50
Hi Dan,
Thanks for your answer,
I've tried both methods:
PDE Method
I'm confusing about the PDE Methods. In the attached file i tried to integrate a simple function f(x,y)=y but what i obtain disagree with the analytical integral (plotted in Geom 4)
About the projection/extrusion method :
I think that I've understood what you meant :
1) Extruding 2D surface onto the first parallel face of a 3D Prism
2) Projecting 3D Prism along a direction Perpendicular to the second parallel face of the Prism back on the 2D Surface. Since the extruded Surface are "cut" by the obliqued plane. When I project I get the integral from 0 to y.
Am I right ? Because I didn't manage to create the extrusion and projection.
I think the first method could be perfect for my problem, do see in my file where my mistake is ?
Thanks a ton for your help and answers.
Hi Dan,
PDE Method
2009年8月13日 GMT-4 09:36
Hi, you need to constrain the value of u on the lower boundary at y=0 to make the solution unique. Enter -u in the R edit field on boundary 2 and you get the correct solution.
/ Dan
/ Dan
2009年8月13日 GMT-4 09:47
Hi Dan,
It works, thanks a lot !
Hi Dan,
2010年12月15日 GMT-5 13:07
Hi, Dan,
Have you ever tried 3D. My application can be simplified as:
? (? u)=exp(int(-a*z'),z'=0 to z)
note: alpha is dependent on u, so, I can not use an analytical form for the right part of the equation.
To this, assume u1, u2
? (? u1)=u2
du2/dz=-a*u2
As one test step to solve the above problem, I tried to solve the second equation alone by assuming the right part is a known function:
du2/dz=f(x,y,z)
The geometry is a cylinder. The top boundary is set to be R=1-u2=0. other boundaries with G=0, R=0.
However, it is quit slow and says "can not find the solution" sometimes.
Is there any special way to do that in 3D?
Thanks in advance
Jiang
Hi, Dan,
? (? u1)=u2
du2/dz=-a*u2
du2/dz=f(x,y,z)
Thanks in advance
Jiang
2011年7月1日 GMT-4 02:50
Hi all!
I want to use I2(x,b), which is defined as I2(x,b)=int_0^b f(x,y') dy', as a coefficient in a PDE. This PDE has a dependent variable,say 'u'. But, f(x,y) is itself a function of 'u'.
Anybody has an idea how to do it?
Tanmay
Hi all!
Tanmay
