How can one smoothen a piecewisely constant variable?
Posted 2014年5月7日 GMT+8 13:53 0 Replies
Generally a dependent variable in COMSOL is a linear combination of 2nd order finite elements. And a variable u_eg defined as 2nd-order derivative of the dependent variable are essentially piecewisely constant. In case one would like to evaluate further the differential properties of u_eg, direct evaluation d(u_eg, x) will be globally zero. Is there a way to smoothen u_eg, in the sense that it has nonzero derivatives?
I think it's possible to export the data and then define an interpolation function from the data. However it's not very convenient.
Thanks!
Hello Pu Zhang
