Charged Particle Tracing Problems
Posted 2014年5月23日 GMT+8 05:51 Low-Frequency Electromagnetics, Charged Particle Tracing, Particle Tracing for Fluid Flow Version 4.3b 2 Replies
I am trying to simulate the trajectory of a charged particle due to an electric and magnetic field. The magnetic field is due to a multi turn coil, so I used the (mf) study for that. My electric field is from voltage sources, which I made a separate study for using the (es) study.
When I setup the particle tracing, I do not solve for the electric of magnetic fields. I check off "Values of variables not solved for" and I can choose EITHER es or mf solution and not both at the same time. I need to be able use them both at the same time when simulating the trajectory. Any ideas on how to do this? I am quite new to COMSOL.
2 Replies Last Post 2014年5月24日 GMT+8 00:48
