Material Data entering into COMSOL from LUMERICAL
Bhavyabhushan Yadav A.V
I started using COMSOL recently, and whenever we need to add material data to it, for example, the permittivity as function of lambda we must upload an xl file with a table containing the material data.
Previously i used to use LUMERICAL FDTD tool for simulation, and it has a wealth of material data available in it.
I thought it would make my task simpler to just export the material data from LUMERICAL FDTD and use it in comsol rather than creating tables for every new material i use on COMSOL. But, the problem is, in LUMERICAL FDTD when i export the material data it can only output a file in .mdf format. Can you suggest me a easy way to convert this file into a usable format in COMSOL, it will save a lot of time for me to carry out my simulation.
2 Replies Last Post 2014年11月12日 GMT+8 21:20
Posted: 1 decade ago 2014年5月31日 GMT+8 03:20
I found a easier way to do it.
refractiveindex.info website has material data that can be exported into text file.
I found a easier way to do it. refractiveindex.info website has material data that can be exported into text file.
Posted: 1 decade ago 2014年11月12日 GMT+8 21:20
Hello Dear,
You do not need to read .mdf file.
Use commands: getindex, and getfdtdindex in .lsf file of Lumerical
to extract material from Lumerical into text files.
Here is the .lsf file for this purpose:
material="Ag (Silver) - Palik (0-2um)";
fmin=100e12; #100THz
fmax=150e12; #150THz
f=linspace(fmin,fmax,500);
n_exp=getindex(material,f);
n_FDTD=getfdtdindex(material,f,fmin,fmax);
eps_exp = n_exp^2;
eps_FDTD= n_FDTD^2;
file1=material+"(raw).txt";
file2=material+"(FDTD).txt";
for (i=1:length(f)) {
write(file1,num2str(f(i)/1e12)+" "+num2str(real(eps_exp(i)))+" "+num2str(imag(eps_exp(i))));
write(file2,num2str(f(i)/1e12)+" "+num2str(real(eps_FDTD(i)))+" "+num2str(imag(eps_FDTD(i))));
The text files, have 3 columns, one for frequency, the other 2 for real and imaginary parts of epsilon.
You need to convert these 3 column files to 2 column files for entering data into into Comsol. Comsol interpolation function accepts text files of 2 columns only, one column is frequency the other column should either be real or imaginary part of epsilon.
Hope this helps.
Solmaz
Hello Dear, You do not need to read .mdf file. Use commands: getindex, and getfdtdindex in .lsf file of Lumerical to extract material from Lumerical into text files. Here is the .lsf file for this purpose: material="Ag (Silver) - Palik (0-2um)"; fmin=100e12; #100THz fmax=150e12; #150THz f=linspace(fmin,fmax,500); n_exp=getindex(material,f); n_FDTD=getfdtdindex(material,f,fmin,fmax); eps_exp = n_exp^2; eps_FDTD= n_FDTD^2; file1=material+"(raw).txt"; file2=material+"(FDTD).txt"; for (i=1:length(f)) { write(file1,num2str(f(i)/1e12)+" "+num2str(real(eps_exp(i)))+" "+num2str(imag(eps_exp(i)))); write(file2,num2str(f(i)/1e12)+" "+num2str(real(eps_FDTD(i)))+" "+num2str(imag(eps_FDTD(i)))); } The text files, have 3 columns, one for frequency, the other 2 for real and imaginary parts of epsilon. You need to convert these 3 column files to 2 column files for entering data into into Comsol. Comsol interpolation function accepts text files of 2 columns only, one column is frequency the other column should either be real or imaginary part of epsilon. Hope this helps. Best, Solmaz
