Error 2058 when solving geometric parametric sweep
Posted 2010年4月8日 GMT+8 20:54 2 Replies
I use Comsol 3.5.0.494 together with SolidWorks. I defined an assembly out of 2 objects. One object is used twice, the other four times. Geometric parameters are defined by global constants (I checked functions in Solidworks and constants in Comsol).
The bidirectional conenction works o.k. regarding "update" and "initialize" functions. That means after changing variables in Comsol I have to reopen both objects in Solidworks and the assembly afterwards to get the geometry updated.
When I start a parametric sweep from menu Solve->Parametric Sweep->Solve and vary a geometric variable every calculation is correctly done for the original geometry. No sweep. That is as expected, since it is not the geometric parametric sweep.
When I start the geometric parametric sweep from menu File->SolidWorks Connection->Geometric Parametric Sweep->Solve the first calculation aborts with the error: Error: 2058 Failed to connect to Inventor.
Exception:
com.femlab.util.FlException: Failed to connect to#Inventor
Stack trace:
at flcadconnection.cpp, row 28, ()
at com.femlab.commands.CadSyncCmd.c(Unknown Source)
at com.femlab.commands.CadSyncCmd.<init>(Unknown Source)
at com.femlab.gui.actions.FileAction.doSynchronize(Unknown Source)
at com.femlab.api.client.ac.a(Unknown Source)
at com.femlab.gui.FlProgressThread.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.ae.run(Unknown Source)
The reason is not the assembly. I tried to apply a geometric parametric sweep to a simple cuboid. Same Error. Is there any example file I can check?
Thanks for your help!
Clemens
Exception:
Stack trace:
Clemens
2 Replies Last Post 2010年4月9日 GMT+8 15:04
