Automatize Simulations and Changing Parameters
Posted 2014年7月1日 GMT+8 01:46 Version 4.4 4 Replies
I have a very simple model of two thin cylinders which are separated by a certain distance and each have a certain diameter. I then measure the voltage inside a volume, where each cylinder plays the role of an electrode.
I want to run multiple simulations, where I do the following:
- Change the diameter of the cylinders
- Change the distance between the two cylinders
- Run a simulation where the voltage is computed
- Export the results (voltage, current density, and voltage gradients) in a txt file with a filename containing the distance between the two cylinders and their diameter.
For the moment, I do this manually, but I have the impression it would be easy to automatize this, as I need to test about 10 different diameters and 10 different distances between the cylinders (so 100 simulations to test all combinations). How can I automatize that?
I read that liveLink can help, or use a batch script... I am not sure what's the best and how to use either of those for my problem.
Thank you in advance for your help.
4 Replies Last Post 2015年1月19日 GMT+8 17:12
