Cyclic Dependencies in an AR coating
Hi all,
I am currently working on modeling an antireflection coating by building a model based off of the Plasmonic Wire Grating tutorial. I have attached the model, so I'll skip over the particulars of how its built. Every time I try to solve, the model generates an error -
"There are cyclic dependencies.
- Variable name: root.comp1.mat12.rfi.n11
Error in multiphysics compilation."
Anyone know what is going on?
4 Replies Last Post 2016年1月1日 GMT+8 17:49
Posted: 1 decade ago 2014年7月23日 GMT+8 03:16
Sorry forgot to attach the file.
Posted: 1 decade ago 2015年5月22日 GMT+8 19:55
Hello Sahil Hasan, I have got the same problem when the version 4.3a is used. If you have solved your problem, could you please tell me the solution? Thanks in advance.
Saeed Mazrouei Sebdani
Posted: 1 decade ago 2015年6月10日 GMT+8 00:11
hi,
could you solve your problem? i am facing the same problem. could you please help me ?
hi, could you solve your problem? i am facing the same problem. could you please help me ?
Posted: 10 years ago 2016年1月1日 GMT+8 17:49
Try to rename the variable n11 (for eg, n11a). Hope it works, for me it worked.
"There are cyclic dependencies. - Variable name: root.comp1.mat12.rfi.n11 Error in multiphysics compilation." Try to rename the variable n11 (for eg, n11a). Hope it works, for me it worked.
