Updating COMSOL variables at each time step
Hi all,
I am trying to solve a model which requires updating a variable (something like a boundary condition) based on the solution at each TIME STEP. I am planning to use MATLAB LiveLink on order to have a control over COMSOL model solution as it progresses in time. I know there is a function to run the study node (something like Model.sol('xxx').run('xxx')); but it does not work for me, as it starts to solve the whole study. I want to have control over time stepping.
A brief description of what is going to happen in my model is as follows:
1. set initial/boundary conditions and start to solve the model
2. advance one time step
3. evaluate some predefined expression (specifically, a line integral of a solution variable)
4. check if this line integral has the value that you expect (e.g. we want it to be equal to 2)
5. if yes, then advance one time step. If not, do this time step again with updated boundary condition (until criteria are satisfied) and then advance in time.
Thanks!
Ali
3 Replies Last Post 2014年11月5日 GMT+8 16:47
Hello Ali Hemmatifar
Ajay Karthik Kunuthur
Posted: 1 decade ago 2014年10月28日 GMT+8 06:24
Hello Ali,
I am facing with similar problem. Please let me know, if you have found a solution or approached this problem with a completely new approach.
Thanking you,
Ajay
Hello Ali, I am facing with similar problem. Please let me know, if you have found a solution or approached this problem with a completely new approach. Thanking you, Ajay
Posted: 1 decade ago 2014年11月5日 GMT+8 10:10
I haven't tried it, but you should be able to define a Probe on your solution and use that Probe value in your boundary condition.
Steven Conrad, MD PhD
LSU Health
I haven't tried it, but you should be able to define a Probe on your solution and use that Probe value in your boundary condition. -- Steven Conrad, MD PhD LSU Health
Posted: 1 decade ago 2014年11月5日 GMT+8 16:47
i never tried how matlab live link works, but i'm sure you can put an 'if'- condition in combination with paremetric sweep.
On model builder SHOW -> check on advance study options
regards
akmal
Hi, i never tried how matlab live link works, but i'm sure you can put an 'if'- condition in combination with paremetric sweep. On model builder SHOW -> check on advance study options regards akmal
