peristaltic pump
I have some question about peristaltic pump the model Comsol, "peristaltic_pump.mph (Model Library Path: COMSOL_Multiphysics / Multiphysics / peristaltic_pump) ".
(a) The Comsol use this equation "netflow=netflowt-(inflow+outflow)/(2*Ttot)", but the correct definition of the net flow would be this equation "netflow=netflowt -outflow + inflow " ? Why of this division (2*Ttot) ?
(b) What would the value of the flow pumped by the end of a cycle?
b.1) Would be the integral outflow over time?
or
b.2) Would be the integral netflow over time?
4 Replies Last Post 2014年9月15日 GMT-4 04:55
Hello Arlindo Garcia
Posted: 1 decade ago 2013年2月20日 GMT-5 09:33
IS this model available in the library readily ?
Posted: 1 decade ago 2013年2月20日 GMT-5 12:02
Hi Nikhil,
You can get the peristaltic pump model from the Model Gallery (Model ID 985) at this website. For what it’s worth the response to Arlindo’s 3 year old question is that the equation for the net flow is “netflowt-(outflow+inflow)/2 = 0”. If you divide by Ttot you get the average volumetric flow rate. The suggested equation “netflowt – outflow + inflow = 0” gives the net change in fluid volume inside the pump.
Nagi Elabbasi
Veryst Engineering
Hi Nikhil, You can get the peristaltic pump model from the Model Gallery (Model ID 985) at this website. For what it’s worth the response to Arlindo’s 3 year old question is that the equation for the net flow is “netflowt-(outflow+inflow)/2 = 0”. If you divide by Ttot you get the average volumetric flow rate. The suggested equation “netflowt – outflow + inflow = 0” gives the net change in fluid volume inside the pump. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 2013年2月22日 GMT-5 06:01
Hi Nagi,
Thanks for your answer, I went through your paper and it was very exciting. we are studying peristaltic pumps as a part of our final year project . Can you please provide us with the model you have developed for academic purposes ? It would be invaluable if you could do so. It is a sincere request.
Nikhil Pingle
Hi Nagi, Thanks for your answer, I went through your paper and it was very exciting. we are studying peristaltic pumps as a part of our final year project . Can you please provide us with the model you have developed for academic purposes ? It would be invaluable if you could do so. It is a sincere request. Regards, Nikhil Pingle
Posted: 1 decade ago 2014年9月15日 GMT-4 04:55
As I m new to comsol..I would like to develop persistaltic pump and valves for my design, I look on to your design in comsol..May I know where the values for "w_fluid" and "netflowt" is given.
I try to run the model,i get following error..may i know why this is happening
"Nonlinear solver did not converge.
Time : 0.1305969132707972
Last time step is not converged"
Looking for your kind responses.
Regards
Yousuf
As I m new to comsol..I would like to develop persistaltic pump and valves for my design, I look on to your design in comsol..May I know where the values for "w_fluid" and "netflowt" is given. I try to run the model,i get following error..may i know why this is happening "Nonlinear solver did not converge. Time : 0.1305969132707972 Last time step is not converged" Looking for your kind responses. Regards Yousuf
