error message in setting up contact problem
I have tried to set up a contact problem for 2 different solid objects. When I tried to solve the problem, the following message will show up:
"Error: 7220
All variables solved for must be treated in at least one segregated solver step."
Can anyone advise me on how to tackle this error? Is there something I must do before doing a contact problem.
Thank you for your help!
John
1 Reply Last Post 2009年8月17日 GMT-4 12:20
Posted: 2 decades ago 2009年8月17日 GMT-4 12:20
I am also working on the contact recently. There is a very good model in the library, you can start from it.
www.comsol.com/showroom/gallery/1431/
Basically, you need to create a contact pair first, then try to play with the initial pressure and penalty factor.
I am also working on the contact recently. There is a very good model in the library, you can start from it. http://www.comsol.com/showroom/gallery/1431/ Basically, you need to create a contact pair first, then try to play with the initial pressure and penalty factor.
