Modeling fluid flow
Posted 2010年5月20日 GMT+8 23:33 Fluid & Heat 4 Replies
Hello
I am trying to model fluid-structure interaction and keep getting errors. I am modeling fluid flowing out of a channel. The channel is located very close to some other object, so the flow is supposed to interact with this object. I hope I explained the problem well enough to understand it. I am not sure what I am doing wrong but I keep getting these errors :
Error: 6170
Failed to evaluate variable
- Variable: lm7
- Geometry: 1
- Dimension: 3
- Domains: {1}
Failed to evaluate expression
- Expression: lm7
- Expression: lm7
- Expression: mean(lm7)
- Variable: FX_smsld
- Defined as: (((-lm7)*dvol_ale)/dvol)
- Variable: FXg_smsld
- Defined as: FX_smsld
- Expression: diff(((FXg_smsld*u_test-0)*dvol),u_test)
Does anyone know what this means. I am new to comsol and this is definitely not an easy task for me. Also, if anyone has nay suggestions on how fluid-structure interaction should be modeled, maybe some literature that could help.
Thank you
Marina
Error: 6170
- Variable: lm7
- Geometry: 1
- Dimension: 3
- Domains: {1}
- Expression: lm7
- Expression: lm7
Thank you
Marina
4 Replies Last Post 2010年5月21日 GMT+8 04:00
