Mesh visible in solution
Posted 2010年5月25日 GMT+8 23:09 1 Reply
Hi all!
I'm simulating a coupled 3D problem including stokes flow and solid mechanics (there are only small displacements therefore I do not use an ALE) the get the response of a vibrating beam in a fluid. If I plot the velocity field there are slight "discontinuties" which seem to come from the mesh (see attached file, rectangle: solid, rest fluid). My question: Is this a graphical problem? I guess not, but where does it come from? I've seen this effect also in other simulations.
Does anyone have suggestions, how to solve the problem? I would prefer not to use more degrees of freedom (a denser mesh oder higher order elements), since my hardware is rather at the limit.
Thanks for any suggestions.
Philipp
Philipp
1 Reply Last Post 2010年5月27日 GMT+8 03:58
