Flux linkage calculation (V3.5a)
Hi there!
I would like to know how do I calculate flux linkage from magnetic vector potential, Az? I came across a paper in user conference 2007 (attached). It gives the equation for flux linkage calculation which can be implemented in COMSOL by subdomain integration. I do not quite understand how to go about it. I would really appreciate if anyone can help me out.
For your information I am modelling a generator.
Your time is greatly appreciated.
Thanks!
2 Replies Last Post 2010年6月22日 GMT+8 08:04
Posted: 2 decades ago 2010年6月17日 GMT+8 22:54
Hi Amissa,
Have you reached any conclusion considering the flux linkage?
I also have the same question!!
Regards!!
Hi Amissa, Have you reached any conclusion considering the flux linkage? I also have the same question!! Regards!!
Posted: 2 decades ago 2010年6月22日 GMT+8 08:04
Hi there Joao
I seem to get the shape of the flux linkage versus current curve, but I am not too sure whether it is the correct way.
Based on my readings, the 2D problems have only the z component of magnetic potential vector, A.The line integral is taken as the unit depth in z direction. Hence, the line integral between two paths is A1-A2. The total magnetic flux per unit depth between two points is just the difference in vector potential between those two points.
In my case I take the magnetic potential vector across 2 winding and minus them times the length of my machine.
I hope I am reading the correct data..
Thanks.
Hi there Joao I seem to get the shape of the flux linkage versus current curve, but I am not too sure whether it is the correct way. Based on my readings, the 2D problems have only the z component of magnetic potential vector, A.The line integral is taken as the unit depth in z direction. Hence, the line integral between two paths is A1-A2. The total magnetic flux per unit depth between two points is just the difference in vector potential between those two points. In my case I take the magnetic potential vector across 2 winding and minus them times the length of my machine. I hope I am reading the correct data.. Thanks.
