comsol 4.0 how to have unequal scaling on different axes
Posted 2010年6月9日 GMT+8 18:52 Geometry, Results & Visualization Version 5.0 9 Replies
options->axes/grid settings the option that the axes not be equal.
I have problems where dimension along one of the axis are microns while along the other axes they are cm.
in 3.5a after unticking axes equal, I could use the zoom extents tool to display my results so that the short dimension could be expanded to fill the screen.
I am struggling with 4.0 now. In geometry (model builder) such a possibility exists.
I have not been able to find this possibility once I have results.
When I extrude a 2D object 5 microns in the z direction to get a 3D object from a 2D drawing made in a working plane, I do not know how to view that.
It is also a necessity to be able to define correctly some of my boundaries.
It is also necessary to be able to view the results!!!
I do not understand where this possibility is hidden. I am not sure it even exists.
if not, please include this ASAP.
Can someone help??
I'm afraid this "feature is not yet in V4.0 but on the list for things to kome soon, but for selecteng you have the selection list to the left
Hope thishelps a little, but I agree, uneven scales is essential in MEMS, and I'm sure it will come
In fact in V4.0a the "unequal scale" is THERE (also for 3D!), just as you have the thin layer easily added to simple 2D or 3D shapes sucha as blocks or rectangles.
Uncheck the "View - AXIS - Preserve Aspect ratio check box"
But you should do a "REFRESH or APPLY" (the ring on the upper border of the window) BEFORE you hit the zoom to extend, otherwise the check box is reset !
I needed help from support to find it, so it could have been here for 4.0 too, I just missed it
Have fun Comsoling
I'm finding it difficult to get uneven axis scaling using version 4.2a.. Please can you help with directions on how to make this work?
To clarify, go to Model > Definitions > View 1 > Camera, and uncheck the "Preserve aspect ratio" checkbox. It seems that the axes are then scaled such that the model looks like a cube, even when its aspect may be 100:1:1.
I have a similar problem with a very long but thin geometry. I can do as mentioned, but I don't want my results as a cube since a lot of information is found at the edges. Is it possible to rescale but keep the rectangular shape? I use COMSOL 4.3.
Thanks in advance!
Theresia
