Rotordynamics Problem
Hello I wanted to obtain Campbell diagram for the given geometry (image attached). As I am new to COMSOL I wanted to know what is a good starting point to solve this problem.
2 Replies Last Post 2015年3月13日 GMT+8 01:33
Posted: 1 decade ago 2015年3月12日 GMT+8 15:29
Search In the Model Library for the model rotating_blade. This model contains an example of a Campbell diagram.
Henrik
Hi, Search In the Model Library for the model rotating_blade. This model contains an example of a Campbell diagram. Regards, Henrik
Posted: 1 decade ago 2015年3月13日 GMT+8 01:33
Thank you Henrik I checkout the problem, and know how to do rotordynamic analysis, but I am more concerned about how to setup simply supported beam boundary conditions at the end of the shaft. The example is of a cantilever beam (Fixed at one end) in my case the ends are supported by bearings (which I assume as simple supports.
Regards
Thank you Henrik I checkout the problem, and know how to do rotordynamic analysis, but I am more concerned about how to setup simply supported beam boundary conditions at the end of the shaft. The example is of a cantilever beam (Fixed at one end) in my case the ends are supported by bearings (which I assume as simple supports. Regards
