Snow medium/material
Dr. Mohmmad Wajid Acoustic Signal Processing
Is snow material available in COMSOL library? If not, how can I generate the same.
2 Replies Last Post 2015年3月15日 GMT-4 06:36
Posted: 10 years ago 2015年3月15日 GMT-4 05:41
There are so may types of snow with varying crystal size, moisture and density. I would use properties of ice the properties of which you can google. Snow is "porous ice" with pores filled with water or air.
Interesting question, though :)
br
Lasse
There are so may types of snow with varying crystal size, moisture and density. I would use properties of ice the properties of which you can google. Snow is "porous ice" with pores filled with water or air. Interesting question, though :) br Lasse
Posted: 10 years ago 2015年3月15日 GMT-4 06:36
'Porous ice' may be a useful approximation for electromagnetic properties but probably not for acoustic properties.
There is some literature on the topic, e.g. arxiv.org/abs/1502.01284 and eprints.lib.hokudai.ac.jp/dspace/bitstream/2115/20232/1/A20_p23-63.pdf
I am sure you can find a lot more. The last resort is certainly to measure the properties you need in snow samples.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
'Porous ice' may be a useful approximation for electromagnetic properties but probably not for acoustic properties. There is some literature on the topic, e.g. http://arxiv.org/abs/1502.01284 and http://eprints.lib.hokudai.ac.jp/dspace/bitstream/2115/20232/1/A20_p23-63.pdf I am sure you can find a lot more. The last resort is certainly to measure the properties you need in snow samples. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
