2 decades ago
2009年9月2日 GMT-4 01:19
A user's guide for the SNOPT 7 optimizer can be found at:
www.cam.ucsd.edu/~peg/papers/sndoc7.pdf
From the abstract, "SNOPT finds solutions that are locally optimal," it uses a gradient approach.
In our experience the COMSOL optimizer code is good if you are optimizing (perhaps) a few parameters. However if you have a dozen parameters then it will probably require a Matlab script and the Matlab 'Optimization Toolbox' (e.g. use a GA).
smoss
http://www.cam.ucsd.edu/~peg/papers/sndoc7.pdf
smoss
2 decades ago
2009年9月2日 GMT-4 02:13
I use it regularly, for the doc it should be in the .../doc folder, if you have the option. I agree with Moss that if you have up to a dozen variables its quickly set up, allthough the "variable"GUI window in 3.5a has some limitations, such as no "MOVE UP/DOWN" and when yuo enter many variables you always have to "apply" each two, as the list is too short, and is only updated after an apply.
But its true that for many variables (I use up to about 40 for my Zernike) a script i easier.
In anycase you can always do otimising without the toolbox, at least for 1-2 variables (otherwise you will find yourself rewriting the module), you can find some examples in an otherwise highly recommendable book to understand COMSOL internals such as:
www.comsol.com/academic/books/mmwfem/
good luck
http://www.comsol.com/academic/books/mmwfem/
good luck
