vector dot product
I was wondering if we could evaluate vector dot products between vector fields? If yes, it would really help a lot in enhancing the way we can use field overlap integrals, among others, in postprocessing.
I am presently using 3.5a but if it is possible only in 4.0 then it might speed up my transition to 4.0.
7 Replies Last Post 2012年6月13日 GMT+8 14:41
Posted: 2 decades ago 2010年6月21日 GMT+8 19:48
you can enter any equation in the postprocessing. So if you have a vector field A=(Ax, Ay, Az) and a vector field B=(Bx, By, Bz) just enter the expression AxBx+AyBy+AzBz. You can also define an expression like dotproduct=AxBx+AyBy+AzBz and use it in postprocessing or anywhere else.
You are not restricted to the suggestions COMSOL gives you. You can use any variable, internal ones and the expressions you define yourself.
Regards
Edgar
Hi, you can enter any equation in the postprocessing. So if you have a vector field A=(Ax, Ay, Az) and a vector field B=(Bx, By, Bz) just enter the expression AxBx+AyBy+AzBz. You can also define an expression like dotproduct=AxBx+AyBy+AzBz and use it in postprocessing or anywhere else. You are not restricted to the suggestions COMSOL gives you. You can use any variable, internal ones and the expressions you define yourself. Regards Edgar
Posted: 2 decades ago 2010年6月21日 GMT+8 20:02
Thank you for your response Edgar. I wonder how I missed out on that? :)
Posted: 2 decades ago 2010年6月22日 GMT+8 00:51
there are still some subtilities for complex values, check the "realdot()" operator, usefull among other for EM/RF fields, but also in other cases
Have fun Comsoling
Hi there are still some subtilities for complex values, check the "realdot()" operator, usefull among other for EM/RF fields, but also in other cases Have fun Comsoling Ivar
Posted: 2 decades ago 2010年6月23日 GMT+8 22:43
Thanks Ivar for suggestion. Seems useful, like always :)
Posted: 1 decade ago 2011年6月1日 GMT+8 02:48
the relevant section from 4.0a,
The Realdot Operator
• The expression realdot(a,b) treats complex numbers a and b as if they were real-valued vectors of length 2 and returns their dot product. You can also think of the operator call as a shorthand form of real(a*conj(b)). This expression, however, is not an analytical function of its complex arguments and therefore has no unique partial derivatives with respect to a and b.
• The difference between realdot(a,b) and real(a*conj(b)) is that the partial derivatives of the former with respect to a and b are defined as conj(b) and conj(a), respectively, while for the latter expression, the partial derivatives are real(conj(a)) and real(a).
• The difference between the partial derivative definitions is important during sensitivity analysis of frequency-response problems (scalar or vector Helmholtz equations).
• Common objective function quantities like power and energy must be redefined in terms of realdot(a,b) rather than real(a*conj(b)) for the sensitivity solver to compute correct derivatives. This applies also to the absolute value, abs(a), via the definition |a|^2 = realdot(a,a).
[QUOTE] check the "realdot()" operator [/QUOTE] the relevant section from 4.0a, The Realdot Operator • The expression realdot(a,b) treats complex numbers a and b as if they were real-valued vectors of length 2 and returns their dot product. You can also think of the operator call as a shorthand form of real(a*conj(b)). This expression, however, is not an analytical function of its complex arguments and therefore has no unique partial derivatives with respect to a and b. • The difference between realdot(a,b) and real(a*conj(b)) is that the partial derivatives of the former with respect to a and b are defined as conj(b) and conj(a), respectively, while for the latter expression, the partial derivatives are real(conj(a)) and real(a). • The difference between the partial derivative definitions is important during sensitivity analysis of frequency-response problems (scalar or vector Helmholtz equations). • Common objective function quantities like power and energy must be redefined in terms of realdot(a,b) rather than real(a*conj(b)) for the sensitivity solver to compute correct derivatives. This applies also to the absolute value, abs(a), via the definition |a|^2 = realdot(a,a).
Posted: 1 decade ago 2012年6月13日 GMT+8 06:23
What if I have a parametric solution, and I want to calulate the dot product of the complex E, from two solutions?
Is the following expression right?
real= real ( with(1,Ex)*conj(with(2,Ex)) + with(1,Ey)*conj(with(2,Ey)) + with(1,Ez)*conj(with(2,Ez)) );
imaginary= imag ( with(1,Ex)*conj(with(2,Ex)) + with(1,Ey)*conj(with(2,Ey)) + with(1,Ez)*conj(with(2,Ez)) );
What if I have a parametric solution, and I want to calulate the dot product of the complex E, from two solutions? Is the following expression right? real= real ( with(1,Ex)*conj(with(2,Ex)) + with(1,Ey)*conj(with(2,Ey)) + with(1,Ez)*conj(with(2,Ez)) ); imaginary= imag ( with(1,Ex)*conj(with(2,Ex)) + with(1,Ey)*conj(with(2,Ey)) + with(1,Ez)*conj(with(2,Ez)) );
Posted: 1 decade ago 2012年6月13日 GMT+8 14:41
I believe so, or you could use the realdot() operator, but I do not believe your equation writing will be simpler
It is a pitty we cannot write out the vector product in a more compressed way
Hi I believe so, or you could use the realdot() operator, but I do not believe your equation writing will be simpler It is a pitty we cannot write out the vector product in a more compressed way -- Good luck Ivar
