geometry inside another geometry
İ just started working on Comsol and going through the basic tutorials. The problem i am encountering at the moment is let's say i am working on 2D ( i have similar issues in 3D). İ create a rectangle and place it inside a circle. Now if i want to perform any operation like Boolean, transform etc, i am not able to select the rectangle. Only circle is being highlighted, The tutorial videos do not encounter this issue. One solution is using the hiding ribbon but why is this happening in the first place? İ am having this problem in both Version 4.4 and v5.
Hamza
5 Replies Last Post 2015年4月12日 GMT-4 06:51
Posted: 9 years ago 2015年4月6日 GMT-4 03:03
If you use the Select List you see the all possible choices at each level, object, domain, boundary. Choosing Select List is in the main ribbon, More Windows. I have encountered your problem as well, but Selection List allows for choosing inner geometries.
br
Lasse
Hi If you use the Select List you see the all possible choices at each level, object, domain, boundary. Choosing Select List is in the main ribbon, More Windows. I have encountered your problem as well, but Selection List allows for choosing inner geometries. br Lasse
Posted: 9 years ago 2015年4月9日 GMT-4 15:38
it worked but i noticed it is confusing like sometimes 'select and hide ' button was not responding. İ found the select box option easier.
But i wonder why does it happen?
Best Regards
Hamza
Thanks, it worked but i noticed it is confusing like sometimes 'select and hide ' button was not responding. İ found the select box option easier. But i wonder why does it happen? Best Regards Hamza
Posted: 9 years ago 2015年4月9日 GMT-4 18:00
I still find it easier to use the older left-right-click method. This can be set in the preferences. Probably just a matter of taste and because I got used to it over many years.
Ah, to explain: You have to do a series of left clicks until the desired feature gets highlighted and then you select it with a right click. Sometimes it is required to zoom in to get the wanted thing highlighted.
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
I still find it easier to use the older left-right-click method. This can be set in the preferences. Probably just a matter of taste and because I got used to it over many years. Ah, to explain: You have to do a series of left clicks until the desired feature gets highlighted and then you select it with a right click. Sometimes it is required to zoom in to get the wanted thing highlighted. -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 9 years ago 2015年4月10日 GMT-4 15:15
To add on to what Edgar said, you can also use your mouse wheel to quickly move through all possible selections beneath your cursor until you get the desired domain as opposed to multiple left clicks.
Posted: 9 years ago 2015年4月12日 GMT-4 06:51
thanks alot
thanks alot
