Error evaluating variable
I am trying to model a heat transfer and mass diffusion process using the PDE module using the coefficient form and general form as function of "C" concentration and "T" temperature. However, keep getting the following error:
Failed to evaluate variable.
- Variable: u
- Geometry: 1
- Domain: 1
Failed to evaluate expression
- Expression: u
- Plot: surf1 (Surface)
I am rather new with COMSOL Multiphysics. Any guidance would be greatly appreciated.
Best regards.
4 Replies Last Post 2015年4月17日 GMT-4 09:22
Posted: 1 decade ago 2015年4月13日 GMT-4 01:39
Your variables are C and T, there is no u. Look at the equations of your physics. Change the plotting variable.
Your global equations have variables vt and wt. What are they? I did not find them defined anywhere.
br
Lasse
Hi Your variables are C and T, there is no u. Look at the equations of your physics. Change the plotting variable. Your global equations have variables vt and wt. What are they? I did not find them defined anywhere. br Lasse
Posted: 1 decade ago 2015年4月14日 GMT-4 01:03
I don't understand why it is looking for "u" if there is not "u" either. How do I change the plotting variable?
vt and wt are the accumulated heat and mass as function of time respectively.
Ernesto
br
Lasse
Hi, I don't understand why it is looking for "u" if there is not "u" either. How do I change the plotting variable? vt and wt are the accumulated heat and mass as function of time respectively. Regards, Ernesto [QUOTE] Hi Your variables are C and T, there is no u. Look at the equations of your physics. Change the plotting variable. Your global equations have variables vt and wt. What are they? I did not find them defined anywhere. br Lasse [/QUOTE]
Posted: 1 decade ago 2015年4月14日 GMT-4 01:22
Just type T or C in the box where the variable to be plotted is defined. Usually in the PDE node "u" is the generic variable name. Why you have C and T beats me, an earlier Comsol version?
I do not see variables vt or wt defined anywhere, neither v or w (vt and wt would then be their time derivatives). Your Intop1 and Intop2 are identical.
br
Lasse
Hi Just type T or C in the box where the variable to be plotted is defined. Usually in the PDE node "u" is the generic variable name. Why you have C and T beats me, an earlier Comsol version? I do not see variables vt or wt defined anywhere, neither v or w (vt and wt would then be their time derivatives). Your Intop1 and Intop2 are identical. br Lasse
Posted: 10 years ago 2015年4月17日 GMT-4 09:22
I am using COMSOL 4.2. I added the parameters "u" and "u2" under the global parameter definition and it solved the problem.
Thank you very much for your advice.
Hello, I am using COMSOL 4.2. I added the parameters "u" and "u2" under the global parameter definition and it solved the problem. Thank you very much for your advice. Best regards,
