joule heating physics under cryogenic conditions
Posted 2015年4月22日 GMT+8 20:05 Electromagnetic Heating, Heat Transfer & Phase Change Version 4.4 0 Replies
I am working on joule heating physics under cryogenic temperatures. My model consist a copper disc of 50 mm diameter and 5mm thickness. This disc is made to dip in liquid helium at 4.2K . I am exciting this disc with a point current source of value 0.01A and a ground point respectively. Also applying convective heat flux on all faces with known heat transfer co efficient (h) values. I have given Initial temperature value as 4.2K also T(external) value as 4.2K. After simulation entire domain seems to be at 4.2K, not even a single milikelvin raise in the temperature. I also changed initial values to room temperature but after simulation it would display me the uniform room temperature again . I haven't made any separate domain for liquid helium, i have just applied temperature with h value.
so to get varying temperature profile due to this excited current source on my copper disc do i need to make it adiabatic by providing thermal insulation on all faces ie neglect convective heat flux . I am so confused with boundary conditions in heat transfer physics.
Since i am a new one on this tool ,Can anyone help me out to get the temperature profile on copper disc due to current excitation maintained at 4.2K.
With regards,
Vignesh
Hello Vignesh Krishna
