Hello Guillaume Tyson
10 years ago
2015年6月8日 GMT-4 23:49
Hi, i encounter a problem, which is similar. Are you sure the future computation base on E*Udotdot + D*Udot + K*U == L rather than Ec*Udotdot + Dc*Udot + Kc*U == Lc. Do you know the relationship between Ec and E . I want the matrix for the future computation in temporal discretion. And I find Null*E*Null' does not equal to Ec.
Could you express for me in details!
Thanks a lot!
Thanks a lot!
10 years ago
2015年6月9日 GMT-4 07:06
So if you check in the COMSOL documentation you'll find in "About the Time-Dependent Solver" exactly what equation COMSOL solves.
I'm not quite sure I understand what the "eliminated" matrices are but to answer your question, what I am sure of is that with the matrices from above, the equation is written:
E*Udotdot + D*Udot + K*U == F
Where F is a new vector containing the flux terms for the different dofs. There are two ways to calculate F:
-Either you use the complete system residuals at each time step that are actually in matrix L. This means that at any time step you would calculate F by:
F = E*Udotdot + D*Udot + K*U + L
This is very slow.
-Or you assemble F yourself from the boundary conditions of your problem. This can be tricky and I had to ask support for help but it works very well and is very fast.
Also maybe your problem comes from the presence of additional dofs. You can turn them off by clicking the "Show" button in the Model Builder then ticking "Discretization". You'll see that in your model interface, under the "Equation" drop-down menu a "Discretization" drop-down menu has appeared. "Compute boundary fluxes" should be checked, turn this option off and then the vector U in Matlab should have as many lines as the system matrices.
Hope this helps,
Guillaume
This is very slow.
Hope this helps,
Guillaume
10 years ago
2015年6月15日 GMT-4 22:51
Thank a lot~
the problem i am concerned is the mass or damping matrix.
for example, briefly, how to extract the mass matrix of poisson equation with certain boundary condition.
Could you give me future help ?
Best regards!
- Zhu Shuai
Thank a lot~
Best regards!
- Zhu Shuai
10 years ago
2015年6月16日 GMT-4 02:44
The problem is that you can't really extract the boundary conditions. After the call MAT = mphmatrix(model, 'sol1', 'out', {'L'}), MAT.L will be the load vector. As soon as you specify a solution number ( ie mphmatrix(model, 'sol1', 'out', {'L'}, i) for the i-th solution time) MAT.L will become your equation residuals.
You should probably aim to rebuild the the load vector manually in MATLAB.
Guillaume
Guillaume
10 years ago
2015年6月16日 GMT-4 04:10
Thanks you!
So, we can also operate the boundary condition for the mass matrix in the same way. Is there any easy way to implement it via Comsol ?
Best Regards!
---ZhuShuai
Thanks you!
Best Regards!
---ZhuShuai
9 years ago
2015年12月13日 GMT-5 17:01
Hi Guillaume,
Have you found the reason of this added 'internal DOFs'? Or did you get the correlation between the solution vector U (via getU) and other vectors? I need to extract the U, modify it and then assign it back to variables, thus I have to know how the U is formatted.
Regards
Hao
Hi Guillaume,
Regards
Hao
Lars Gregersen
COMSOL Employee
9 years ago
2015年12月14日 GMT-5 06:55
Hi Hao
You can use the function mphxmeshinfo to get information the matrices returned by mphmatrix and the internal degrees of freedom. The data returned by mphxmeshinfo is documented in the Programming Reference Manual under XMeshInfo in the chapter on solvers.
Rregards
Lars Gregersen
Comsol Denmark
Hi Hao
Rregards
Lars Gregersen
Comsol Denmark
9 years ago
2015年12月14日 GMT-5 19:44
Thanks Lars, I will check that part.
8 years ago
2016年11月16日 GMT-5 04:03
It seems that 5.2a version has fixed this bug about Lc&L stuff. Just in case anyone would face this problem.
Guillaume
[QUOTE]
Guillaume
[/QUOTE]
