Using selections of edges in virtual operations
I created a selection of edges which I wanted to ignore in my model using the virtual operation 'Ignore Edges'. I was surprised to discover that in the IgnoreEdges operation I can only select domains, but not my selection of edges. Is this intentional?
Thank you
Daniel
1 Reply Last Post 2015年5月6日 GMT-4 09:00
Bjorn Bretz COMSOL Employee
Posted: 10 years ago 2015年5月6日 GMT-4 09:00
Dear Daniel,
You can specify the edges to ignore in an Ignore Edges node by referring to an edge selection that is defined in the same geometry sequence. If this does not work for you or if you have more specific questions in this issue, I recommend you to contact COMSOL support (www.comsol.com/support/case/).
Sincerely,
Bjorn Bretz
COMSOL Development
Dear Daniel, You can specify the edges to ignore in an Ignore Edges node by referring to an edge selection that is defined in the same geometry sequence. If this does not work for you or if you have more specific questions in this issue, I recommend you to contact COMSOL support (http://www.comsol.com/support/case/). Sincerely, Bjorn Bretz COMSOL Development
