How to do integration of two different eigenfunctions?
I am using comsol 3.5a. I am doing eigenvalue analysis in pde mode, and
I would like to do subdomain integration of expresion
witch contains two different eigenfunctions. For example u(of first eigenvalue)*u(of second eigenvalue).
Is it possible to do what I want in GUI? If not, how to do it in .m file?. Thanks.
2 Replies Last Post 2010年7月15日 GMT-4 18:26
Posted: 1 decade ago 2010年7月15日 GMT-4 17:25
there are two interesting operators to understand:
with() and at()
one to select a particular solution, the other for a time series from a solution
check the doc it's too long to say everything here
Goog luck
Hi there are two interesting operators to understand: with() and at() one to select a particular solution, the other for a time series from a solution check the doc it's too long to say everything here Goog luck Ivar
Posted: 1 decade ago 2010年7月15日 GMT-4 18:26
Thanks again.
I did exactly what I wanted. I simply put:
conj(with(3,u))*y*with(1,u)
In the expressions line in subdomain integration window in GUI.
And I got the matrix element I wanted.
Thanks again. I did exactly what I wanted. I simply put: conj(with(3,u))*y*with(1,u) In the expressions line in subdomain integration window in GUI. And I got the matrix element I wanted.
