                                2015年6月9日 GMT+8 23:22
                                                    I think Carreau and Carreau-Yasuda are used interchangeably and refer to the same. COMSOL uses for former term.
One has the option of selecting a user-defined model if the built-in models don't meet your needs.
Steven Conrad, MD PhD
LSU Health
LSU Health
                                2015年6月10日 GMT+8 18:40
                                                    I have solved this problem using a user defined viscosity:
eta_0*(1+(lambda*spf.sr)^a)^((n-1)/a)
The Carreau model, with a=2, is a specific form of the more general carreau-yasuda model.
                                2015年6月10日 GMT+8 22:04
                                                    Can you tell me how can I add herschel-bulkley parameters or Bingham Plastic properties?
                                2015年6月11日 GMT+8 09:41
                                                    James, thanks for the clarification
Himanshu, you can provide any equation that provides a dynamic viscosity value, and you have the COMSOL variable spf.sr available for the shear rate.
I have not worked with Bingham fluids, but here are my thoughts. Consider using a very large limiting viscosity for a shear rate (spf.sr) under a given value (to simulate the yield stress), and the characteristic plastic viscosity above that value. The COMSOL if() function can be used to select the value based on shear rate. The result will have to be smoothed with a Heaviside function to eliminate the discontinuity.
This can be extended to the Herschel-Bulkley model by applying a shear thinning/thickening coefficient such as spf.sr^(n-1). The article at
en.wikipedia.org/wiki/Herschel–Bulkley_fluid gives an even more generalized approach based on shear rate.
If anyone sees any problem with this approach, please advise!
LSU Health
This can be extended to the Herschel-Bulkley model by applying a shear thinning/thickening coefficient such as spf.sr^(n-1). The article at http://en.wikipedia.org/wiki/Herschel–Bulkley_fluid gives an even more generalized approach based on shear rate.
LSU Health
