Large Deformation and Hyperelasticity of Shell Elements
Posted 2015年5月30日 GMT+8 01:13 Structural Mechanics 2 Replies
I am currently working on modeling shell elements in COMSOL, and my material will undergo large deformations. Thus, there is a good chance that a hyperelastic material model will be required. Under the shell physics, I only found a linear material model, so I was wondering if there is a way to use nonlinear models as well (whether the shell elements could be modified or other models could be imported into the module).
Additionally, I am having problems with the material's large deformations when it is modeled as a shell. When using plates or beams, I check the "include geometric nonlinearity" checkbox in study1r>step1:stationary and use segregated step as demonstrated in one of the COMSOL examples titled "large deformation analysis of a beam." However, this same procedure does not produce the large deformation for a shell element. It is still bending for a case of small deformation (no bending/curling is occurring, just vertical tip displacement). Are there extra steps that need to be taken for a shell element?
Additional information about the model: the material is subject to an internal distributed moment (body load) and an internal axial stress. The paragraph above is for just the distributed moment case. I later plan on using this model in the multibody dynamics module.
Anil Erol
The Pennsylvania State University
Anil Erol
2 Replies Last Post 2015年6月5日 GMT+8 00:14
