2 decades ago
2010年8月5日 GMT+8 23:04
if you are in 2D, in fact you are still solving for 3D but by default COMSOL considers 1[m] depths (depends on the application mode/physics) this has it's importance if you calculate forces or torques as the units must remain consistent and a motor of 10cm depth or 1m depth should give you 10x more torque, if you keep the rest idntical. now COMSOl often renormalises over the depth too, that is why it's so important to always consider the units. Loads are mostly applied as presures [N/m^2=Pa] so ifyou have total forces in [N] you need to divide the value by the active surface,. before you enter tzhis value into a comsol load defined in pressure. thereis a good similitude with the 2D-3D relation via the depth. All depends if you are looking on a variable that scales with "z" the in plane dimension
Hope this helps
Hope this helps
2 decades ago
2010年8月5日 GMT+8 23:25
Hi, thanks for your reply.
As you said, I am doing simulation in 2D and the value I want to get is the torque of a rotating machine. if I leave the L to be 1m, the torque I get is 104 N*m. AfterI changing L to 0.1m, I still get 104 N*m, but it should be 104/10=10.4 N*m, right? So how can I setup the variable to see this change in torque as the length of the machine varies?
2 decades ago
2010年8月6日 GMT+8 02:01
Notfully I believe, because the reply from COMSOL is obviously normalised since it does not change when you change the depth.
To get the absolute force you need to divide by 0.1[m] as you write out phyiscally in your equation.
This is so, I believe, to allow easy trsansfer from one physics to another
