Two Stream Simulation
Posted 2015年7月16日 GMT+8 03:26 Fluid & Heat, Geometry, Mesh, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 5.1 0 Replies
Running the simulation with just one fluid is simple. But I'd like to simulate two different fluids of different viscous values to show the viscous effects closer to the chamber walls. To properly understand how to use two different fluids, i'm using water and transformer oil for now, before becoming more complicated. However, even so, when running the study, it isn't converging. I tried changing the size of the mesh but to no avail. It would be great if i could get some advice for this. I also used the same two fluids with different geometry *a more basic 2D dimensional instead of 2D axisymmetrical* and it worked. So I'm quite unsure as to what I'm doing wrong in the First attached file.
Respectfully,
Ezekiel.
Hello Ezekiel Yorke
