(HELP!!!) Integration coupling variables problem
integration coupling variables->boundary variables problem
I am simulating a fluid flow using Poisson's equation in a 2d environment(2d square).
Fluid is taken as it is entering from the top boundary and exits from the bottom.
And there is not pressure on the side walls so no fluid flows through side walls.
In the simulation the fluid is supplying nutrients to cells, nutrient supply is modeled by the convection and diffusion equation.
I want to find the mean velocity, Ud at y=d, at the top boundary(boundary 3) with an expression k*Py and destination to be the sub domain 1.
I entered these values in "integration coupling variables->boundary variables". When I solve for the initial concentration of Nutrients (solution of the convection and diffusion) I am getting an error.
Please help me!
3 Replies Last Post 2015年7月19日 GMT-4 09:35
Posted: 10 years ago 2015年7月17日 GMT-4 02:58
it would be easier for us to understand if you join in the model too ;)
Hi it would be easier for us to understand if you join in the model too ;) -- Good luck Ivar
Posted: 10 years ago 2015年7月17日 GMT-4 03:34
Thank you for the reply
Attached is the comsol file(I am using comsol 3.5),
I want to find the initial value of N.
These are the steps I followed, Solver manager->initial value expression + use setting from initial value frame
then in the "solve for" tab solve "heat equation"
I got an error when solving this, But when I take out the mean velocity term it worked.
Thank you for the reply Attached is the comsol file(I am using comsol 3.5), I want to find the initial value of N. These are the steps I followed, Solver manager->initial value expression + use setting from initial value frame then in the "solve for" tab solve "heat equation" I got an error when solving this, But when I take out the mean velocity term it worked.
Posted: 10 years ago 2015年7月19日 GMT-4 09:35
anyone there?
anyone there?
