How do we set the axis in comsol 5?
I want to limit the x,y axis in comosl 5? I cant find a way to set the axis manually.
2 Replies Last Post 2015年7月22日 GMT-4 20:11
Frank van Gool COMSOL Employee
Posted: 10 years ago 2015年7月21日 GMT-4 03:48
Dear Ash,
that would be under the "view node" in the definitions.
Sometimes this node is present in post processing as well. This happens when the component dimension is different than the plot you are creating (3D component and 2D plot).
For 1D plots you can change the axis limits in the "plot group node".
I hope this helps.
Frank
Dear Ash, that would be under the "view node" in the definitions. Sometimes this node is present in post processing as well. This happens when the component dimension is different than the plot you are creating (3D component and 2D plot). For 1D plots you can change the axis limits in the "plot group node". I hope this helps. Best regards, Frank
Posted: 10 years ago 2015年7月22日 GMT-4 20:11
Thank you very much!
it worked
Thank you very much! it worked
