Hello Rinaldo Gonzalez Galdamez
2 decades ago
2010年10月18日 GMT+8 19:56
Got an answer?
Got an answer?
2 decades ago
2010年10月18日 GMT+8 21:31
I never got an answer through this forum but I did get a couple of replies in the COMSOL yahoo forum. I have been able to set up a model using the phase field method. The level set method does not work well for high velocity flows. Besides the usual multiphase flow settings, numerical stabilization is needed. Also, I set a coupling variable for the surface tension in the subdomains where fluids are present, this seemed to help.
Are you trying to model something similar?
2 decades ago
2010年10月18日 GMT+8 21:42
Yep,
I've started to think about the problem... May you address me to the mentioned helpful material?
And thank you for the respond!
Stephan
Yep,
Stephan
2 decades ago
2010年10月29日 GMT+8 01:27
I apologize for the late response.
Look carefully into the "Boiling Water" tutorial. specifically into the "delta" scalar expression for the integration coupling variables- subdomain variables. Also look at the settings for the artificial diffusion.
I integrated these changes into my model and worked fine. let me know how it goes.
