Heat transfer, air-gap
Posted 2015年8月28日 GMT+8 11:09 Heat Transfer & Phase Change, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 5.0, Version 5.1 1 Reply
i currently try to model the heat transfer through multi-layer wall structures. These structures are filled with an air gap, measuring about 50mm between the shells.
I already have the experimental data for the transmittance factor and it differs alot from the transmittance factor i get from the simulations (for example u_simulation=0.6 W/m²K and u_simulation=0.3 W/m²K).
The simulation is pretty simple:
Heat transfer through solids for the solid parts and heat transfer through fluids for the air gap.
I think radiation plays a minor role here.
Do you think i should include natural convection in the air? (How? Using "laminar flow" like the example "vacuum_flask.mph"? ) I was told, convection here is not important...
Or any other effects, i couldnt think of?
The values i get from the simulation for structures without an air gap are matching the experiment, but as soon as a air gap is introduced, the values differ a lot.
Thanks alot!
Thanks alot!
1 Reply Last Post 2015年8月28日 GMT+8 13:43
