El Capitain
Does anyone know if Comsol will work with the new OS X operating system or will it require an update?
2 Replies Last Post 2015年10月10日 GMT+8 21:35
Posted: 1 decade ago 2015年10月3日 GMT+8 03:48
The next version of COMSOL Multiphysics, version 5.2, will be compatible with OS X El Capitan. We expect this version to be released later this fall. Initial tests indicate that the current version 5.1 will also work with OS X El Capitan. However, more extensive testing is under way to determine if any software update is needed.
[Updated 10/6/15] Further testing revealed that there are certain stability problems with running version 5.1 with OS X El Capitan. We are continuing our investigations and will post new information as it becomes available.
The next version of COMSOL Multiphysics, version 5.2, will be compatible with OS X El Capitan. We expect this version to be released later this fall. Initial tests indicate that the current version 5.1 will also work with OS X El Capitan. However, more extensive testing is under way to determine if any software update is needed. Best, Jeff [Updated 10/6/15] Further testing revealed that there are certain stability problems with running version 5.1 with OS X El Capitan. We are continuing our investigations and will post new information as it becomes available. Best, Jeff
Atanas Kumbarov COMSOL Employee
Posted: 1 decade ago 2015年10月10日 GMT+8 21:35
COMSOL 5.1 Update 3 is compatible with Mac OS X El Capitan after applying a dedicated patch. See www.comsol.com/product-update/5.1-mac-os-10-11
Atanas Kumbarov
COMSOL 5.1 Update 3 is compatible with Mac OS X El Capitan after applying a dedicated patch. See http://www.comsol.com/product-update/5.1-mac-os-10-11 Best regards, Atanas Kumbarov
