Joule heating and thermal expansion
Posted 2015年10月15日 GMT-4 06:31 Electromagnetic Heating, Structural Mechanics 1 Reply
1. Material has a significant deformation (20 mm) on the Von Mises stress 3D plot. But on line graph the value of deformation is normal (0.3 mm). Maybe we interpret stress graph incorrectly? Does this graph include deformation?
2. There is deformation value while the pressure applied but deformation is constant. We have 0% of deformation in case of 0 Pa applied, but any other pressure value leads to constant deformation value of 20 mm in z-axis direction (in case of several Pa or several MPa). So, it looks like deformation on 3D graph is not sensitive to pressure change. Also, as it was in 1., deformation is normal on line graph and there is a change as it is expected.
What can be a reason of such mismatch between 1D and 3D plots?
thanks
Hello Anastasiia Tukmakova
