How do I get the nodes associated with a boundary.
Posted 2015年11月19日 GMT+8 03:50 Interfacing, Geometry, Modeling Tools & Definitions, Structural Mechanics Version 5.1 0 Replies
I have a model (Solid Mechanics). I have one component in that model.
1. I have defined some constraints on some boundaries.
2. I have defined a boundary load as well.
3. I have a mesh (tetrahedral).
I would like to see if I can get the nodes in the mesh that are associated with the boundaries that are constrained and loaded.
My objective is to export the mesh (which I have done successfully) and export the boundary conditions (constraints and loads) to be used in an external solver. I am using the Java API to get the boundaries for the constraints and loads but all I get are boundary numbers and am unable to correlate the boundary numbers to element/node numbers.
Appreciate any help you can give.
Thanks.
Hello Shekar Mantha
