Plastic dissipation calculation: solid.Wp
Hello everyone,
I am running a time dependent model of a crack growing and propagating in an elasto-plastic medium (solid mechanic module) and i am analyzing its energy balance evolution in function of time.
I was curious to know how the plastic dissipation energy density (solid.Wp) is calculated by Comsol. I looked into the equation thanks to the option "equation view" but i didn´t find anything. Does anyone know how this variable is calculated?
Thank you very much,
Rémi
1 Reply Last Post 2017年9月14日 GMT+8 16:14
Posted: 8 years ago 2017年9月14日 GMT+8 16:14
Hi Rémi,
The reason you cannot see it in Equation View, is because it is integrated internally (just as the plastic strains themselves). The expression for the rate of Wp can be found in the theory section of the structural mechanics documentation. Look for 'Energy Dissipation' and 'Numerical Solution of the Elastoplastic Conditions'. Basically it is integrated using a 'backward Euler' method.
Regards, Henrik
Henrik Sönnerlind
COMSOL
Hi Rémi, The reason you cannot see it in Equation View, is because it is integrated internally (just as the plastic strains themselves). The expression for the rate of Wp can be found in the theory section of the structural mechanics documentation. Look for 'Energy Dissipation' and 'Numerical Solution of the Elastoplastic Conditions'. Basically it is integrated using a 'backward Euler' method. Regards, Henrik
