Interpolation function in variable
Posted 2011年10月26日 GMT+8 23:12 Heat Transfer & Phase Change, Materials Version 4.2a 3 Replies
I want to use a temperature depending interpolation function for the thermal conductivity (Cp)
I made an interpolation graph in the global definitions. (named int1)
There in X-axis it is temperature in degC
and in Y axis it is Cp (J/Kg K)
now I want to use this graph in my heat transfer mode
I think I need to make a variable called Cptemp with a link to int1
but there I get always the following
unknown variable int1
in the heat transfer mode I would change then Cp from material to user defined.
How can this basic problem be solved?
3 Replies Last Post 2011年10月27日 GMT+8 14:32
