"wait" option missing when using COMSOL/Matlab with a scheduler (Python)
I am using COMSOL/Matlab with a scheduler (Python).
For ordinary Matlab it is possible to use the wait option, e.g. matlab -nodesktop -minimize -r -wait "checkMail, exit", which tells the scheduler to wait till 'checkMail.m' is completed.
Reference: www.mathworks.com/access/helpdesk/help/techdoc/ref/matlabwindows.html
However, the "wait" option does not work for COMSOL/Matlab, e.g. C:/Programme/Comsol35a/bin/comsol.exe matlab -ml /nodesktop -ml /nosplash -ml /wait -mlr "flreport('off'), mainprogram, exit"
This holds, even though COMSOL tells, that the ordinary Matlab options can be used:
www.comsol.com/support/knowledgebase/980/
Is there any way to use the "wait" option?
I ended up writing an ASCII file and telling the scheduler to wait for this file to be written.
Contacting COMSOL support was not very helpful, at least so far.
Andreas
1 Reply Last Post 2010年3月14日 GMT-4 10:48
Hello Andreas Kapp
Posted: 1 decade ago 2010年3月14日 GMT-4 10:48
I had exactly the same problem and couldn't get the wait option to work. What i eventually did was create a batch file for each model i wanted to run and then created a main batch file which called each one of these individually using: "start /wait <path>\Batch.bat".
So my main batch file looked like:
start /wait <path>\Batch1.bat
start /wait <path>\Batch2.bat
start /wait <path>\Batch3.bat
start /wait <path>\Batch4.bat
and the contents of for example Batch1.bat was:
start c:\COMSOL35\bin\comsol.exe matlab -ml /nodesktop -ml /nosplash -mlr "cd <path_to_model>; model1".
Not sure if this helps you though as havent used python scheduler
I had exactly the same problem and couldn't get the wait option to work. What i eventually did was create a batch file for each model i wanted to run and then created a main batch file which called each one of these individually using: "start /wait \Batch.bat". So my main batch file looked like: start /wait \Batch1.bat start /wait \Batch2.bat start /wait \Batch3.bat start /wait \Batch4.bat and the contents of for example Batch1.bat was: start c:\COMSOL35\bin\comsol.exe matlab -ml /nodesktop -ml /nosplash -mlr "cd ; model1". Not sure if this helps you though as havent used python scheduler
